12-10-2017, 12:09 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | two methods, one use voulme down and connect cable, two root and enable diag by adb |
The Following User Says Thank You to zishhaider For This Useful Post: |
12-10-2017, 14:00 | #5 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 677934 Status: Offline Thanks Meter: 28 | |
12-10-2017, 22:00 | #6 (permalink) | |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote: | |
12-30-2017, 08:34 | #9 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00009601 MODHW : 0000100C BUILD : MPSS.JO.1.0.c5-00051-M8909EAAAANVZM-1.46590.1.66140.1 RTIME : Feb 14 201710:08:42 BTIME : Aug 08 201607:00:00 DEVST : 8909.gen Update IMEI[1] : 843256921126xxx Record update Ok! Update IMEI[2] : 843256921126xxx Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:03 Reconnect Power/Cable! |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
