Old 12-12-2016, 13:37   #1 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
Red face lenovo a1000m sc7731 frp error
i have lenovo a1000m sc7731 i need to remove frp but cnot
i try on with another pc but same please any idea ?/
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 87 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Reconnect Power/Cable!
The Following 2 Users Say Thank You to genci titi 2002 For This Useful Post:
Old 12-12-2016, 14:12   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
For start - try select correct SC773x loader.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 12-12-2016, 14:22   #3 (permalink)
Member: 2521585
Thanks Meter: 167
The Following User Says Thank You to AL DRFEL For This Useful Post:
Old 12-12-2016, 17:54   #4 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
Red face
i try it sir. but same problem i select sc773x
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 12-12-2016, 18:23   #5 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
i try it on checked Reset via SVC
but frp not removed
Operation : Format File System / Reset Settings [ v1.24 ]
Settings : SmartFormat is On
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 150 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Init Ok , reset settings ...
Format Ok!
Done
Elapsed: 00:00:22
The Following 3 Users Say Thank You to genci titi 2002 For This Useful Post:
Old 12-12-2016, 19:07   #6 (permalink)
JayDi's Avatar
Member: 462970
There is FEW SC773x + ALtLDR for every of them. One will work anyway.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-12-2016, 19:20   #7 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
yes i remove frp from another way... and i see on devices info has sc7731g
Old 12-12-2016, 19:24   #8 (permalink)
JayDi's Avatar
Member: 462970
A1000
http://forum.gsmhosting.com/vbb/f296...l#post12036268
A1000m
http://forum.gsmhosting.com/vbb/12055095-post47.html
Next time just try do what explained, instead of do nothing.
Old 12-23-2016, 09:10   #9 (permalink)
Member: 411207
Thanks Meter: 164
how do you remove.i face some problem here
Old 04-11-2018, 12:03   #10 (permalink)
trt
Member: 197566
Thanks Meter: 89
choose loader 773x andr 5.0. in flash tab select original firmware .pac
when do unlock.
The Following User Says Thank You to trt For This Useful Post:
Old 06-04-2018, 14:10   #11 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 578
when do unlock.
yes its works thx
thx for yor help
Page generated in 0.17946 seconds with 8 queries
