12-15-2015, 11:23 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Location: Russia, Kyshtym Age: 43
Member: 153541 Status: Offline Thanks Meter: 0 | Lenovo A2010-a Google account block This device was reset.To continue, sign in with a google account that was previously synced on this device. How reset. Latest Flash firmware Does not help Downgrade firmware Does not help Reset privacy lock Does not help Reset user lock Does not help Operation : Check / Read Info [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D5332370A400042B39042FE DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200400AFE4272B3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A2010-a ProdModel : Lenovo A2010-a Device : A2010-a AndroidVer: 5.1 MTKxCPU : MT6735M MTKxPRJ : A2010-a-t_USR_S243_1508130100_MP3V1_8G_ROW MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V8_P31_1_lwg_ n Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
12-15-2015, 12:23 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This come after HardReset/Wipe from phone settings. And there is no reason to use "Reset Locks" options. Enough kust make Factory Reset and software will remove FRP also. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
02-03-2016, 14:48 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 104 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 460001154D3232378133004211AEB956 DA Stat : v4.2 on BBID : 0x93 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
02-11-2016, 04:13 | #8 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Kemaman,Terengganu,Malaysia
Member: 2420663 Status: Offline Thanks Meter: 22 | http://forum.gsmhosting.com/vbb/member.php?u=462970 HI,,I newbie here...i wanna ask about this google account verication that locked my device from using it..is there any solution here to fix this...and this infinity box can solve this issue? for samsung,sony,lenovo and any android 5.1 devices?? |
02-11-2016, 04:16 | #9 (permalink) |
Member: 2420663 Status: Offline Thanks Meter: 22 | @JayDi HI,,I newbie here...i wanna ask about this google account verication that locked my device from using it..is there any solution here to fix this...and this infinity box can solve this issue? for samsung,sony,lenovo and any android 5.1 devices?? |
02-11-2016, 04:17 | #10 (permalink) |
02-11-2016, 04:18 | #11 (permalink) |
02-12-2016, 06:27 | #13 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Quote:
check here Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 460001154D32323764C80042DD279FC4 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200C864C49F92DD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! | |
03-07-2016, 16:11 | #14 (permalink) | |
Freak Poster Join Date: Dec 2010
Member: 1478562 Status: Offline Thanks Meter: 54 | Try this method first download full flash file from google.... Quote:
The Following User Says Thank You to www.prasanna.g For This Useful Post: |
03-07-2016, 16:21 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @www.prasanna.g, next time, before make stupid and useless posts, try check thread, where you do that. Infinity users not mind about such things, as twrp or anything else, so, leave your pity advises for "peoples" like you. |
