06-12-2018, 11:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | world first LG X240 imei repair problem solve Error code: QAZ6CQAWB5 http://forum.gsmhosting.com/vbb/f799...wered-2416442/ open cm2mtk select setting tab sp:select model 6571..6797 lgx210 select go to security tab imei tab wirete imei and cm permanent method . direct ok imei repair no problem Card found : S/N : 43Exxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 79 ] Sync... Init Service mode failed, something went wrong Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 79 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741CB36A432AF1A6BB4 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x30000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A436CBB46B15AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x3BB46FD2E6B9D9E8DD80EC8F21AB1F2D INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok IMEI [00] : 3538xxxxxxx IMEI [01] : 3538xxxxxxx Set IMEI [00] : 35271xxxxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 34 ] Sync... Repair done! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to turkcellgsm For This Useful Post: |
06-22-2018, 08:33 | #2 (permalink) |
Member: 395431 Status: Offline Thanks Meter: 458 | read flash Card found : S/N : 43xxxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 79 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447414437A432BF1964A4 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x30000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A43744A46415BF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x3BB46FD23D5BA1332BB7FF2D4BE13EC7 INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! xGPT : Normalize settings Ok! Brand : lge ProdName : mlv3_global_com ProdModel : LG-X240 Device : mlv3 AndroidVer: 6.0 CU_SWVer : X24010f MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.115_arima6737m.65.m0_P211 [Read Ok] : preloader_lv3.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : flex.img [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : lk2.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / lv3 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 3620 MiB Scatter saved to : C:\Users\uzmanbilir\Desktop\MT6737M__lge__LG-X240__mlv3__6.0__alps-mp-m0.mp1-V2.115_arima6737m.65.m0_P211\ All done! Done! Elapsed: 00:08:02 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to turkcellgsm For This Useful Post: |
11-27-2018, 09:16 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hey.. can u pls share the preloader or full firmware..? | |
11-29-2018, 14:04 | #4 (permalink) |
Member: 395431 Status: Offline Thanks Meter: 458 | other phone write flash direct dead phone not open. Dosya.tc - Ücretsiz, H?zl? ve Kolay Dosya Payla??m? |
11-29-2018, 14:29 | #5 (permalink) | |
let me check it.. i have 2 dead phone.. | |
11-29-2018, 14:36 | #6 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | writing preloader done.. it is flashing by octopus now.. Code: Write : PRELOADER Update bootloader code ... Update bootloader Ok! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:00:29 |
