06-07-2016, 09:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | Lenovo A3000-H preloader problems. A really weird one My customer killed this tab. The result is erased preloader. I tried to reflash but it's impossible bcose i tried all avaliable flash (from xda, from russian forums, from lenovo forums, all international and chinese) on the net without success. The preloaders supports only one kind of samsung flash ic. I checked all available logs (like this) Only samsung flash. The tab builded with Hynix and it's original of course. It's possible to edit or rebuild the preloader? thx log: Code: User selected Preloader file : preloader_a3000_row_3gdata.bin Operation : Init Preloader [ v1.48 ] Supported HW by Preloader : FlashID [0] CID : 1501004B4A5330304D , Name : KJS00M , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 176 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741A2010204A76072A9 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A2A97260A7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x4DB973FDA3D78ADB8BBD16167EC90239 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 1501004B4A5330304D , Name : KJS00M , Vendor : 15 , [SAMSUNG] STORAGE : BL NOT support this eMMC! Select Correct One! |
06-07-2016, 09:19 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Not possible edit preloader without it sources. But possible find any similar, which will work on it. BTW it initialized well with ScatFW, which you selected in flashing tab. What if enable skip HW check and flash it? |
06-07-2016, 09:39 | #3 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | thx but not working Can you explain the preloader requeriments? I have to find one hw ckeck deselected: Code: Wait for phone... Phone found! [ 176 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741A2010204A76072A9 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A2A97260A7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x4DB973FDA3D78ADB8BBD16167EC90239 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Disabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase Error! Something went wrong! Operation Failed Elapsed: 00:02:17 Reconnect Power/Cable! |
06-07-2016, 09:57 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SPFT should also stop on Pre-Erase with some SDMMC_ERASE_ERROR or SDMMC_WRITE_ERROR. Seems as dead end for FlashIc. I had optimized MT6589 operations with latest loaders in MTKv1.49. MTK change much in last version and it work more correct now. Try it, just to make sure. I had tested 5x different MT6589 for all kind of operations, including whole erase and rebuild. If result same - then it FlashIC ReadOnly. |
