Old 10-04-2017, 18:36   #1 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
lenovo a319 hang on logo
i flash lenovo a319 but just hang on logo can any help me to solve problem?
here is log
Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447316404050BA23D446285
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404050BA23D446285
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xE0153C46B65A324BE3359277E8D0A4C4
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3765 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin72_cwet_1a_kk.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:10
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:01:17
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:58
Reconnect Power/Cable!
Old 10-04-2017, 18:38   #2 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
i try just flash not done i try full format then flashed but same hang on logo
Old 10-04-2017, 18:40   #3 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
here is info before i flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Lenovo
ProdName : A319
ProdModel : Lenovo A319
Device : A319
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : A319_ROW_DS_S318_150615
Done!
Elapsed: 00:00:10
Old 10-04-2017, 23:09   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,284
Flash with older SPFT (v3.1344.0.212), with "DA DL Checksum", and both checksum checking enabled
from Options Drop-Down menu.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 10-05-2017, 09:50   #5 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
b.r.
Alex
Brka i try with your advice but its same only lenovo logo.Do you have any suggestion this phone drive me crazy
Old 10-05-2017, 10:08   #6 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 629
Hello Mr. trenac,
Please Do This with CM2MTK ----
HW Test ( Tick Test[FlashIC], Test[RAM], Test[Other] ) & click Make Test....
Then see your eMMC Condition....
When any error or any problem in eMMC Then Final Solution ----
Use any Jtag box,
1. remove eMMC from PCB,
2. connect eMMC in Jtag Box through Adapter,
3. Make Universal Factory Format,
4. write GPT Partition,
5. Now select Scatter file & Write directly in eMMC by Jtag Box,
6. after Flashing complite Replace eMMC ic in PCB,
7. Power on Device
Now 100% ur hang on logo problem solve & Device on perfectly...
<---< That is my Garantee
Old 10-05-2017, 10:24   #7 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 629
Here Is Video Link
Micromax D321 Hang On Logo Problem Solved (Normal Flashing Can't Solve This).....
https://www.youtube.com/watch?v=G4lX3ca6H7Q
You apply same process for ur Device...
Please Like, Share My Videos & Subscribe My Channel
The Following User Says Thank You to Pijush Das For This Useful Post:
Old 10-05-2017, 16:57   #8 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
here is test result
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3900 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A483447316404050BA23D446285
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:33
Old 10-05-2017, 18:02   #9 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 629
Your eMMC condition 100% OK...
So, try Flash with Latest version SP Flash Tool...
1. Format,
2. Flash & Check Device Condition...
When Problem Same, Then I'm sure this Hang on log problem comes from Hardware,
So, find fault in Hardware...
...*...THANK YOU...*...
Old 10-05-2017, 18:47   #10 (permalink)
UzUnlocker's Avatar
Member: 1912005
Sonork: 100.1658592
Thanks Meter: 383
reflash phone - Power On and wait 5-20min.
Old 10-06-2017, 18:51   #11 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
not work i think its hardware problem
Old 10-06-2017, 19:21   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
Hello,
First do Flash erase,then
Write back its backup if still hang on Logo,write same stockrom with same Filename as backup.
Old 10-06-2017, 19:30   #13 (permalink)
Member: 2408050
Thanks Meter: 8
Not hardware. Its software. I flashed more than 50 a319 and I have 7 firmwares of different version of the same model phone. Maybe you are flashing wrong firmware.
Try "ROW DS 313" if "ROW DS 318" didn't work. But before trying other firmware, If you can still see logo then I'd say you have the right preloader. But if your display went black or showing blurry images then you have to change the firmware. Btw you should initialize the preloader once before trying to flashing it again. Try init preloader from the extra tab of cm2 mtk by choosing the preloader bin file of your firmware then flash the firmware again. Don't turn on the phone after flashing. Try to charge it by a usb charger. Plug the charger's usb cable and wait. You should see the battery image and after some time you will see the charging animation with charge percentage. If you can see the animation then you are sure you flashed the right firmware. Turn the phone on while charging and wait 3 to 10 minutes and voila! you will see the welcome screen. But if you see nothing or only the battery logo but no animation for 20/30 seconds after plugging the charger then you must have to flash different firmware. Press thanks if I helped.
Sent from my Primo_EF3 using Tapatalk
The Following User Says Thank You to cleshera For This Useful Post:
Page generated in 0.39642 seconds with 7 queries
