lenovo A3800-D UNFORTUNATELY GOOGLE HAS STOP lenovo A3800-D UNFORTUNATELY GOOGLE HAS STOPPED I FORMAT AND EVEN FLASH BUT STILL THE SAME ANYONE WITH THE SOLUTION Card found : S/N : A6936825 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A3800 ProdModel : Lenovo A3800 Device : A3800 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : A3800_USR_S227_1705250900_MP3DSV1_BMAIN_CN SECURITY : BTMAC Addr : 74042B379112 WiFi MAC : 74042B4B9112 MODEM : BaseBand : MT6290_S01_MOLY_LR9_W1423_MD_LWTG_CMCC_MP_V3_5_ltg _n EXTRA : LCD [0] : ili9806e_dsi_vdo_wvga_txd_tongxingda LCD [1] : hx8379c_dsi_vdo_wvga_KV4072CB LCD [2] : hx8379c_dsi_vdo_wvga_chuangshi LCD [3] : ili9806e_fwvga_dsi_txd LCD Res : 854x480 TOUCH [0] : ft6x06 TOUCH [1] : msg2133a CAM [0] : ov5670_mipi_raw CAM [1] : gc0312_yuv CAM [2] : hi704_yuv CAM [3] : hi551_mipi_raw MODEM : mt6290_ltg_l700mp LOCALE : zh_CN en_US Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Lenovo ProdName : A3800 ProdModel : Lenovo A3800 Device : A3800 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : A3800_USR_S227_1705250900_MP3DSV1_BMAIN_CN [Read Ok] : preloader_hq82_slwt_2s_b1b_td.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / hq82_slwt_2s_b1b_td / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 886 MiB Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6582__Lenovo__Lenovo_A3800__A3800__5.1__A 3800_USR_S227_1705250900_MP3DSV1_BMAIN_CN\ All done! Done! Elapsed: 00:04:50 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : hq82_slwt_2s_b1b_td , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lenovo Device Model : A3800 Device CPU : MT6582 Device IntName : A3800 Device Version : 5.1 Device Compile : 12/30/2014 2:10:40 PM Device Project : A3800_USR_S227_1705250900_MP3DSV1_BMAIN_CN Device ExtInfo : Lenovo A3800 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : hq82_slwt_2s_b1b_td , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3774 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5D00000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hq82_slwt_2s_b1b_td.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:12 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:18 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:51 Reconnect Power/Cable! Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6290_S01_MOLY_LR9_W1423_MD_LWTG_CMCC_MP_V3_5_ltg _n NVM Read Ok, MT6290_S01_MOLY_LR9_W1423_MD_LWTG_CMCC_MP_V3_5_ltg _n_eMMC.spnv Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12953C27DB2299 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D12953C27DB2299 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3724A5BB29503A598B43C197AD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3616 mV [Processing] FlashMemory Read-Write test [eMMC] : [MICRON] , M49J1 , 0xE9800000 , 3736 MiB [eMMC] : CID : FE014E50314A39344D12953C27DB2299 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:51 Reconnect Power/Cable! |
hi It's emmc issue need to change or reprogramme |
I have a lenovo A3800,is it safe to flash with A3800d firmware?Its doing the same unfortunately has stopped |
