10-18-2015, 09:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | lenovo a388t sc8830 flashing problem. identify with cm2 Code: Chinese Miracle II [SPD module] v 1.05 Start at : [10/17/2015 / 10:53:34 PM] Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Generic Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A388t Model Brand : Lenovo Model Device: A388t AndrVersion : 4.1.2 BaseBand CPU: SP8830EC CompileDate : 1395358355 Project Ver : MocorDroid4.1.2 Model Ext : Lenovo A388t ExtraInfo : HWInfo not exists, normal phone ExtraInfo : TDMA Phone Elapsed: 00:00:19 Reconnect Power/Cable! Finish at : [10/17/2015 / 10:53:53 PM] Code: Start at : [10/17/2015 / 10:59:03 PM] Operation : Flash [ v1.05 ] ======= Flash Files set for flashing : [ MCU ] : Lenovo A388t_S248_140605.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S248_140605 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1C records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_TD Current File : modem.bin Flashing now ... [FlashProc] : Error with code 0x0002 try many firmwares same problem Code: Chinese Miracle II [SPD module] v 1.05 Loading : Lenovo A388t_S235_140115.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S235_140115 FastCheck : 0x19C461C9 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin File : SC8830.xml Load Ok! Start at : [10/17/2015 / 11:33:12 PM] Operation : Flash [ v1.05 ] ======= Flash Files set for flashing : [ MCU ] : Lenovo A388t_S235_140115.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S235_140115 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1C records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Error with code 0x0002 Code: Loading : Lenovo A388t_S235_140115xg.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S235_140115xg FastCheck : 0x213D8649 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin File : SC8830.xml Load Ok! Start at : [10/18/2015 / 12:00:53 AM] Operation : Flash [ v1.05 ] ======= Flash Files set for flashing : [ MCU ] : Lenovo A388t_S235_140115xg.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S235_140115xg File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1C records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Error with code 0x0002 Code: Chinese Miracle II [SPD module] v 1.05 Loading : Lenovo A388t_S241_140320_Lang_By_Kyle_Final.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S241_140320_Lang_By_Kyle_Final FastCheck : 0x1E8FD5B7 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin File : SC8830.xml Load Ok! Start at : [10/18/2015 / 12:02:43 AM] Operation : Flash [ v1.05 ] ======= Flash Files set for flashing : [ MCU ] : Lenovo A388t_S241_140320_Lang_By_Kyle_Final.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC8830 PacVersion : Lenovo A388t_S241_140320_Lang_By_Kyle_Final File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1C records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Error with code 0x0002 what is problem .. hw problem or other need help /suggestion |
10-18-2015, 09:25 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello .As can see from logs - it stops randomly at sending data requests. Can you try charge battery fully and try with ReasearchDownload to make sure? Untick backup in settings on second page. |
10-18-2015, 11:14 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | there is also same error - it disconnects by some reason during flash. Check battery. If still nothing change - then you need open phone and check it/solder. |
