02-19-2016, 13:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Lenovo A526 MT6582 Preloader Dead Problem Operation : Check / Read Info [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1552.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3557564D42019FBB45C931C1 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Please give me preloader file for Repair... |
02-19-2016, 15:06 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try this preloader- Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-18-2016, 15:42 | #3 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | now my set also dead after flash Wait for phone... Phone found! [ 109 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040508A1CEC12155 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040508A1CEC12155 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76D405961067CCD02981B98A380551B3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004B3557564D42 , Name : K5WVMB , Vendor : 15 , [SAMSUNG] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Failed, Reflashing required! All Done Done! Elapsed: 00:00:21 Reconnect Power/Cable! in it preloader failed-any way to recover--help me |
The Following User Says Thank You to zone3 For This Useful Post: |
