10-10-2017, 11:43 | #2 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1259614 Status: Offline Thanks Meter: 57 | Card found : 5A9C3263 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Connect device in fastboot mode ... Connect Ok! Trying set EDL mode ... If device not reboot in EDL - use KEYS combination/EDL cable/TP Operation finished! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0B236227 ID_BLOCK_I : 007050E1 ID_BLOCK_L : BC443ED877E3E81BC4B95B4483DE5676 ID_BLOCK_L : FE953B92870EB035C82768A1A3425C7F Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 173 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img ProgStart : start 461920, num 262160 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
