lenovo a6010 recovery contacts but not photo Phone is reboot, if "repair data/cache/msc" photo delete in phone? Recovery contacts ok but how recvery photo, button not active? Operation : Recovery UserData [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 17062E09 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 9E661CFA55C1CEF9A69B755AA5FC7454 ID_BLOCK_L : DDB01EB1A22D9D16AB0A4F848E617F5C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Direct access : Ok! Recovery PhoneBook ... Read Ok, extract ... Load Ok! Verify Ok! Details : 0x6432,0x0986,C89A Export HTML Ok Export VCF Ok Contacts count : 325 Data saved to : C:\InfinityBox\CM2QLM\phdata\Data_export\17062E09_ __MSM8916__Lenovo__Lenovo_A6010\ Done! |
All data will be deleted. We work on fotensic and will be activated in near release. |
Hello @podeev, Until you get the update for the forensic you can follow the following tutorial to recover the data you want... http://forum.gsmhosting.com/vbb/f296...guide-2195031/ Want mOre, Check this http://forum.gsmhosting.com/vbb/f296...guide-2245206/ Good Luck, |
