04-13-2016, 17:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | Lenovo A680 erased Preloader after factory flash I attach a log file of my A680 being flashed. Code: Chinese Miracle II [MTK module] v 1.43 Scatter Load Ok , BaseBand : MT6582 , Project : huaqin82_wet_e_jb5 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [2016.04.12. / 23:04:56] Operation : Flash [ v1.43 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048602A3D853B09F Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A3D853B09F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 20FF588D6028E8388EA8B2B08121B215 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : huaqin82_wet_e_jb5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4068 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x0000000093400000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin82_wet_e_jb5.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:15:24 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:17 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:16:14 Reconnect Power/Cable! Finish at : [2016.04.12. / 23:21:09] whatsoever. Now Preloader is erased according to this log: Code: Chinese Miracle II [MTK module] v 1.43 Scatter Load Ok , BaseBand : MT6582 , Project : huaqin82_wet_e_jb5 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [2016.04.13. / 16:33:48] Operation : Flash [ v1.43 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048602A3D853B09F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBF0B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:01:09 Reconnect Power/Cable! Finish at : [2016.04.13. / 16:34:55] Supported HW by Preloader : FlashID [0] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 1501004B3558564D42 , Name : K5XVMB , Vendor : 15 , [SAMSUNG] Any ideas to resurrect this phone? And how to find a A680 flash file that is compatible with it? Thank you. WBR e-studio.hu |
04-13-2016, 18:08 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. That error code indicates RAM calibration error. That error can happen due battery discharge or RAM problems itself. Check phone for water damage. If there is separate eMMC and RAM - resolder RAM only. It should help. |
