05-31-2016, 17:13 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 812868 Status: Offline Thanks Meter: 3 | Lenovo A7-30Hc error 0x2003 please help me... Lenovo A7-30Hc error log: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010048384731650000F69FFE9FB265 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
05-31-2016, 17:21 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Firmware not compatiable with your phone ,seek good firmware & flash again |
The Following User Says Thank You to Kirumira For This Useful Post: |
06-01-2016, 07:33 | #3 (permalink) |
Member: 812868 Status: Offline Thanks Meter: 3 | flash with other firmware error again: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010048384731650000F69FFE9FB265 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! flash erase again error: Operation : Flash Erase [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010048384731650000F69FFE9FB265 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
06-01-2016, 09:32 | #4 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | What was de problem of your phone? Did you made a backup before flashing? |
06-01-2016, 14:30 | #6 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
https://docs.google.com/uc?id=0B25It...EIyd21oYWFrNjQ post logs results | |
06-01-2016, 15:42 | #7 (permalink) | |
Member: 812868 Status: Offline Thanks Meter: 3 | Quote:
Log error: User selected Preloader file : preloader_huaqin82_tb_b2d_kk.bin Operation : Init Preloader [ v1.47 ] Supported HW by Preloader : FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100513858534142 , Name : Q8XSAB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [3] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010048384731650000F69FFE9FB265 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! | |
06-01-2016, 15:56 | #8 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | If you dont have a backup,keep searching for good firmware, compatiable with your tab. |
06-04-2016, 16:45 | #11 (permalink) |
Member: 812868 Status: Offline Thanks Meter: 3 | error after chang cid to CID: 150100513732534D4200F69FFE9FB2E7 Manufacture ID: 15 Manufacture Name: SAMSUNG OEM ID: 0100 Product Name: Q72SMB Product Name Hex: 513732534D42 Product Revision: 00 Product Serial Number: 4137680543 Manufacture Date: 11/1999 error log: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200F69FFE9FB2E7 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBF0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK1_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
02-24-2017, 15:31 | #13 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | maximus max404 black Scatter Load Ok , BaseBand : MT6582 , Project : Pack1 , Storage : EMMC Files found : 1 , Set to Flash : 0 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D433034475886D0794191D3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBF0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK1_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
