05-04-2016, 21:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 497508 Status: Offline Thanks Meter: 23 | Lenovo a7-30hc ...help 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : 00B000B000B000B000B0000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
05-04-2016, 22:44 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Lenovo devices have very bad soldering and weak boards. It can die , if have some damage before - like broken or etc. Try charge battery and repeat flashing try 2-3 times more, but not sure about that will change anything. |
