09-30-2016, 18:13 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Ponkunnam, Kottayam. KERALA Age: 35
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | Lenovo A7000 Plus(A7000-a) IMEI DONE - Android 6.0 Code: Start at : [26-09-2016 / 13:36:35] Operation : Repair Security [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100513832334D4200D3CDC8FFC22F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200D3CDC8FFC22F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xA22D2F435080A0F24702C44E2DE0FD31 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 8690450******** IMEI [01] : 8690450******** Set IMEI [00] : 8690450******** Set IMEI [01] : 8690450******** Prepare finished. Security check required! Wait for phone... Phone found! [ 4 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! Finish at : [26-09-2016 / 13:37:29] Shows error on CM Software BUT IMEI CHANGED USB Debugging is turned ON IF DA DL FAILED - |
The Following 2 Users Say Thank You to pgharidas For This Useful Post: |
10-07-2016, 16:50 | #3 (permalink) |
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | Phone which I got was without IMEI. May be after full format or wrong firmware flashing. IMEI wrote with CM was the original one. But IMEI write in CM is permanent, so if it changed to another it will stay even if do hard reset |
