11-08-2016, 06:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Lenovo A7010 k51c78 NVRAM WARNING: Err = 0x10 Read FW Read NVRAM Reflash it with A7010a48_S219_160810_ROW Now no IMEI, SN, MAC, has BB and NVRAM WARNING: Err = 0x10 Try "Write NVRAM" but same problem NVRAM WARNING: Err = 0x10 How repair it? In Extra Files has backup - nvram.bin, seccfg.bin When try repair IMEI: Code: Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3331338D470642DB020AE4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D4206478DE40A63DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xBD01717801EA7B4DCB89DEBB8F573CC0 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 8678000******** Set IMEI [01] : 8678000******** Prepare finished. Security check required! Wait for phone... Phone found! [ 5 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! But imei - repair But same error : NVRAM WARNING: Err = 0x10 Last edited by Abzal; 11-08-2016 at 06:46. |
11-08-2016, 07:14 | #3 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | I am write backuped nvm: Code: Operation : Write NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3331338D470642DB020AE4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D4206478DE40A63DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xBD01717801EA7B4DCB89DEBB8F573CC0 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [NVCheck] : BBID : MT6753 , NVID : MT6753 [NVM] : Write Ok! [Info] : NVRAM Repair on erased/damaged phone : 1. Fix Unknown BaseBand 2. Power On phone, check BB state 3. Write NVRAM 4. Repair Security Done! Elapsed: 00:00:56 Reconnect Power/Cable! A7010a48_S219_160810_ROW |
11-08-2016, 07:51 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Sure security will gone after convert china version to euro. If there is no baseband - fix it first. otherwise there is no reason try do something other. |
