Old 09-21-2016, 14:37   #1 (permalink)
maqsod's Avatar
Member: 666362
Thanks Meter: 134
lenovo a702048
I just formate after formate fix dl prb
i flash with backup1. Power Off Phone , Remove battery , Insert back
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMB12
[eMMC] : FLASH_CID : 150100523231424D4206A007D8F44317
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x5042ED7A87284872D731BB9B8ABB09EF
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Phone not require that operation!!!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000001A80000
Erase : 0x0000000001BC8000-0x0000000007000000
Erase : 0x000000000A000000-0x0000000001000000
Erase : 0x000000000B300000-0x0000000002480000
Erase : 0x000000000DC80000-0x0000000738F7BE00
Flash Erase Done, time used : 00:00:02
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Failed!
Something wrong with files or connection!
Operation Failed
Elapsed: 00:00:20
Old 09-21-2016, 18:25   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Thanks for the model hint. Device will be on hands after one week ( max 2 week ).
There is some factory FW's available. Did you try flash them?
Old 09-22-2016, 06:21   #3 (permalink)
maqsod's Avatar
Member: 666362
Thanks Meter: 134
I flash with sptool hang on logo
Tool DL image faile showing
any solution
Old 09-22-2016, 13:23   #4 (permalink)
maqsod's Avatar
Member: 666362
Thanks Meter: 134
Phone a live thanks to vijay brd
flash with sptool here is the file
https://mega.nz/#!PYcjjC6S!S401eZCeC...jBq23ITjehDPAg
The Following User Says Thank You to maqsod For This Useful Post:
Page generated in 0.15682 seconds with 9 queries
