12-16-2016, 10:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | HTC 516 Hang On Logo. http://forum.gsmhosting.com/vbb/12168568-post103.html but i can't detect. device manager its show qualcomm hs usb qloader 9008 Any solution. |
12-16-2016, 10:32 | #2 (permalink) | |
Insane Poster Join Date: Jun 2011
Member: 1588686 Status: Offline Thanks Meter: 24 | Quote:
http://server1.infinity-box.com/down...ivers_v1.00.7z reboot system and do your job | |
12-16-2016, 11:41 | #3 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | Quote:
Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! | |
12-16-2016, 13:01 | #5 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
Credit Goes To CYB3R GSM | |
12-16-2016, 14:51 | #6 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | @ahmed koukou Bro can you upload backup for me please .. i connect successfully Quote:
12-16-2016, 15:32 | #7 (permalink) |
Member: 1873645 Status: Offline Thanks Meter: 977 | i can't write backup or format it. Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 04AB601C ID_BLOCK_I : 008140E1 ID_BLOCK_L : 5BF3348E724247AF ID_BLOCK_L : C060A78CDA117663 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Format failed! Error while flashing data! Check cable! Done! Elapsed: 00:02:43 Reconnect Power/Cable! |
03-27-2017, 19:13 | #13 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | can anyone give the readed working firmware of this phone ? i have a dead set which only shows 9008 port . regards Code: Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 02D4CD10 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 956F05F15CCAF7F2AD8272539CE76F5F ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : htc ProdName : htc_asia_india ProdModel : HTC Desire 516 dual sim Device : htc_v2_dug AndroidVer: 4.3 Manufact. : HTC QLMxCPU : MSM8610 Done! Elapsed: 00:00:09 |
08-09-2017, 20:24 | #15 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | hi to all friends i was facing this phone with hang on logo state and flash file was 0PBDIMG_516h V2_DUG_JB43_SENSE51_htc_europe_1.07.401.001_Radio_ LELMC07 i cant flash because phone hasn't fastboot mode so i managed to solve the problem this way 1- using memory tool i connect phone and get differente partitions. 2- then i flashed system.img.unsparse in system partition directly q1: where can i get this system.img.unsparse ????? a1: search and download this file 0PBDIMG_516h V2_DUG_JB43_SENSE51_htc_europe_1.07.401.001_Radio_ LELMC07.zip extract and you will get your needed file. good luck to all |
The Following User Says Thank You to adelkaha25 For This Useful Post: |
