12-29-2017, 13:15 | #1 (permalink) |
Insane Poster Join Date: Dec 2011 Location: pakistan
Member: 1706450 Status: Offline Thanks Meter: 10 | infinity team plz add SECURE BOOT file plz thanks infinity team |
The Following User Says Thank You to greengold786 For This Useful Post: |
12-29-2017, 14:52 | #5 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
12-30-2017, 07:41 | #7 (permalink) |
Member: 1706450 Status: Offline Thanks Meter: 10 | bro i have qmobile i6 metal one2017 inside cpu mtk 6580 but cannot read info when i read info mobile says [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error!.i change boot file but no responce.MT6735/MT6737M have sopport i reset frp done mt6735 6737 |
12-30-2017, 08:16 | #8 (permalink) | |
12-30-2017, 08:48 | #9 (permalink) |
Member: 1706450 Status: Offline Thanks Meter: 10 | bro i say alredy mtk 6735 6737 work fine for me but mtk 6580 cannot work. SECURITYBOOT_BOOT_NOT_ACCEPTED. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
12-30-2017, 08:50 | #10 (permalink) |
Member: 1706450 Status: Offline Thanks Meter: 10 | after change boot file but says 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
12-30-2017, 09:03 | #11 (permalink) |
Member: 1706450 Status: Offline Thanks Meter: 10 | u chack my bro 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42314589DE0742FBB9E5DA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D4207DE89DAE583FB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xBDDE94961ECF2BD0F69B2A2914BD3D90 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [12/27/2017 / 7:57:49 PM] |
