10-04-2016, 09:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | Lenovo a7020a48 frp lock error Card found : S/N : 8F8C34EB , v0134 Chinese Miracle II [MTK module] v 1.57 Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207D62BCA1253AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xF7DA00F94D5491E9117680934F5B3C30 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : A7020a48_USR_S259_1607211026_mp7-V2.3_lenovo6755.66c.m_P67_ROW EXTRA : LCD : Not info available LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : ov8865_mipi_raw CAM [2] : s5k3m2_sunny_mipi_raw CAM [3] : ov8865_sunny_mipi_raw MODEM : STOM_MODEM=koleos2_row_lwctg_md1 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:23 Reconnect Power/Cable! Card found : S/N : 8F8C34EB , v0134 Chinese Miracle II [MTK module] v 1.57 Operation : Fix DL Errors [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207D62BCA1253AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xF7DA00F94D5491E9117680934F5B3C30 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! DA DLFix Passed! Done! software hangs here Elapsed: 00:00:46 Reconnect Power/Cable! |
10-04-2016, 11:47 | #3 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | [QUOTE=JayDi;12078431]Hello. I had order such device already. Hope it will be on hands during this week. thx for reply sir, but customer is getting angry for problem caused in the phone. when i try to write its backup , software erased the file, now phone dont show tool dl image fail..it also gives error in sptool 5.1636. pls help me how to revive the phone.cant write its preloader also. Wait for phone... Phone found! [ 4 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! |
10-04-2016, 14:26 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I can't help you because have no such sample to test and check yet. You killed it now by flashing, by ignore SW warnings. Now you should wait , or search over internet for factory FW and try flash it. |
10-04-2016, 15:03 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try this firmware- https://cloud.mail.ru/public/2qva/NABhR44UZ Br. Infinity Box Support Team. |
10-05-2016, 06:24 | #10 (permalink) | |
Member: 368923 Status: Offline Thanks Meter: 85 | Quote:
10-17-2016, 10:22 | #12 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Hello sir, same condition with me today. I also killed phone today. hope next update fix this problem. I read firmware if u want to test it i will give u link. I try to remove frp lock but after that show tool image fail. handset not on. i try to flash read firmware after that handset dead. Read Information: Code: Card found : S/N : 79306C07 , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D42060EC7C487439D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x01665815825A724860C15DB40BBE261F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : A7020a48_USR_S259_1607211026_mp7-V2.3_lenovo6755.66c.m_P67_ROW EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : ov8865_mipi_raw CAM [2] : s5k3m2_sunny_mipi_raw CAM [3] : ov8865_sunny_mipi_raw MODEM : STOM_MODEM=koleos2_row_lwctg_md1 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:16 Reconnect Power/Cable! B.R., B.Uttam |
10-19-2016, 05:32 | #13 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 477510 Status: Offline Thanks Meter: 40 | MT6755__Lenovo__Lenovo_A7020a48__A7020a48__6.0__A7 020a48_USR_S259_1607211026_mp7-V2.3 . Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D420640CBE038234F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x34D26A443FED20A114EB66634583F367 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : A7020a48_USR_S259_1607211026_mp7-V2.3_lenovo6755.66c.m_P67_ROW [Read Ok] : preloader_k52_a48.bin [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : efuse.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : md3img.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : preload.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / k52_a48 / EMMC Android Info saved HWConfig Info saved FW Size : 3647 MiB Scatter saved to : C:\Users\M YASEEN\Desktop\MT6755__Lenovo__Lenovo_A7020a48__A7 020a48__6.0__A7020a48_USR_S259_1607211026_mp7-V2.3_lenovo6755.66c.m_P67_ROW\ |
12-10-2016, 05:22 | #15 (permalink) |
Junior Member Join Date: Sep 2014 Location: Z.burnu Ist Turkey Frm.Pakistn Age: 31
Member: 2266238 Status: Offline Thanks Meter: 55 | Lenovo A7020a48 Hang on logo sp tool error Try This Method Bro your problem will be solved just uncheck these files in sp tool and you get working device and frp also gone 1 efuse 2 md1img 3 md1dsp 4 md1arm7 5 md3img |
The Following User Says Thank You to baabu.ansar1 For This Useful Post: |
