Old 01-02-2015, 19:21   #1 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Lenovo A830(MTK 6589) repair imei not work correct
Hi I get phone with problem with sounds after change firmware, I write orginal one and after I got damaged IMEI.
I try change imei with CM_MTK_v1.08 and 1 imei change but not 100% and no network in phone.
In phone menu in setting I got 2 IMEI position IMEI and IMEI SV and CM_MTK just change IMEI position , secound one just IMEI SV is 78 and phone not have network.
Any solution for this or nothing soon ?
I can upload full dump if needed.
Old 01-02-2015, 20:38   #2 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Here is full info from phone maybe needed to help me:
Brand : Lenovo
ProdName : A830
ProdModel : Lenovo A830
Device : A830
AndroidVer: 4.2.1
MTKxCPU : MT6589
MTKxPRJ : ALPS.JB2.MP.V1
Saved to : C:\InfinityBox\CM2MTK\Backup\MT6589__LENOVO__Lenov o_A830__ALPS.JB2.MP.V1__Android_4.2.1__20130827_11 4115.ispff
Old 01-02-2015, 20:47   #3 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Please, if possible, post here also log text for imei repair operation, this may helps.
Old 01-14-2015, 14:57   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Here are all log that should help:
Start at : [2015-01-02 / 19:29:39]
Operation : Check / Read Info [ v1.08 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 204A0190594E4958D7A116489340DFF5
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A1D7F5DF4093
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:05
Reconnect Power/Cable!
Finish at : [2015-01-02 / 19:29:44]
Start at : [2015-01-02 / 19:30:36]
Operation : Repair Security [ v1.08 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : MT6589
HW : LENOVO89_WET_JB2_MD1_HSPA_HW
SW : A830.V10
MM : 2000.00.00
VR : 1.0
Security Info :
IMEI [1] : 860364023127060
IMEI [2] : Damaged or not exists
Read Ok!
Update IMEI[1] to : 860364023127060 done!
Update IMEI[2] to : 860364023127060 done!
Done!
Elapsed: 00:00:51
Finish at : [2015-01-02 / 19:31:27]
Old 01-14-2015, 15:12   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello. I will make 2 new way for repair in v1.11 or v1.12 , mostly finished. Still looking for some interest samples.
The Following 3 Users Say Thank You to Dzirt For This Useful Post:
Old 01-15-2015, 14:35   #6 (permalink)
Member: 2085623
Thanks Meter: 221
Thanks but I fix this phone by aplication from play store and fix imei and netowrk work ok. But when get next will try your software again and give know.
Page generated in 0.14090 seconds with 8 queries
