Old 08-30-2015, 12:30   #16 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 623
Originally Posted by JayDi View Post
Because eMMC not allow erase itself. Read-only state.
How can i do now? boss
Old 08-30-2015, 12:32   #17 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 623
if emmc problem why sp flash tool can format and flash this phone?
Old 08-30-2015, 12:33   #18 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,204
Change eMMC to alive one.
Try also make memory test in SPFT.
Old 08-31-2015, 04:19   #19 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1640853
Thanks Meter: 242
try with older versions of Sp flash tools...
Old 08-31-2015, 04:39   #20 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 623
I tried older version same case
Sent from my Primo X2mini using Tapatalk
Old 08-31-2015, 05:56   #21 (permalink)
JayDi's Avatar
Member: 462970
It can simulate this as well.
Already gave hint how check it.
Old 08-31-2015, 08:06   #22 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,459
Can u give me MT6582 Nv file?
Hello,
Here Is Nv File For Your Requirement
Old 01-05-2016, 07:30   #23 (permalink)
Member: 1349362
Sonork: sk
Thanks that was very helpful i flash it with checksum Dl all and thats it
hats off
Old 01-23-2016, 21:29   #24 (permalink)
Member: 1712680
Thanks Meter: 27
Originally Posted by pradeep_kus View Post
Hello,
How to flash that file in the phone?
Br rogeunlock
Old 01-24-2016, 04:54   #25 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 145
After flash Lenovo A880 => TOOL DL image Fail! I try to fix it cm2 fix dl mode fix baseband but stuck cm2mtk.exe hang.
i have solve this problum on lenovo s920 read flash file from falty set with cm2. and wit with sptool with da dll cheked. and set recover with this trick .u can alos try and psot result if worked.
Old 01-24-2016, 06:56   #26 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
Br rogeunlock
Hello,
With Write NVRAM button under Security tab.
Br.
Infinity Box Support Team.
Old 03-07-2016, 07:36   #27 (permalink)
Member: 1678082
Sonork: 12345
Thanks Meter: 11
cm2 flashing set ok LENOVO A889
Old 03-07-2016, 07:53   #28 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 139
I fixed another lenovo handset with dl error
read file with cm2
reflashed it with readed scatter file using cm2 with all options unticked.
Please try it in another lenovo with dl error
and post results
Old 03-07-2016, 08:13   #29 (permalink)
JayDi's Avatar
Member: 462970
Fix DL button not require such long way.
Old 12-16-2017, 06:26   #30 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,539
Try this with Sptools .
Check the two boxs .After check the boxs .in sptool when you before flash select firmware upgrade then start flash .
Page generated in 0.37206 seconds with 8 queries
