Old 07-13-2017, 21:11   #1 (permalink)
Member: 2422331
Thanks Meter: 41
Lenovo FRP remove MT6735
Card found : S/N :xxxxxxxx , v0135
Chinese Miracle II  [MTK module] v 1.58
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x07000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with SLA
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:12
Reconnect Power/Cable!
how to use "DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07" I can't find it
Old 07-14-2017, 02:04   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
And what model exactly is that ? (The one you are trying to remove FRP) ?
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 07-14-2017, 02:22   #3 (permalink)
Member: 2600625
Sonork: aly_alumni_ptc
Thanks Meter: 58
becarefull to act if phone have boot secure brader
Old 07-14-2017, 02:24   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Nothing to be afraid of. I will post 100% working solution,
just waiting for exact phone/device model.
b.r.
Alex
__________________
Old 07-14-2017, 17:46   #5 (permalink)
Member: 2422331
Thanks Meter: 41
b.r.
Alex
https://ibb.co/fTkPxv
Please check
Old 07-15-2017, 08:33   #6 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
You can try other way :
download SpFlashTool v5.1624
take from it DA_SWSEC.bin
rename it to MTK_AllInOne_DA_SP.bin and put in boot folder, but save first original one somewhere.
Repeat operation.
Br.
Infinity Box Team.
Old 07-17-2017, 18:34   #7 (permalink)
Member: 2422331
Thanks Meter: 41
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Repeat operation.
Br.
Infinity Box Team.
I have the same result
Card found : S/N : 8BE23346 , v0135
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-06-15.11:02
Boot Error!
Operation Failed
Elapsed: 00:00:20
The Following User Says Thank You to ChElEuLaVi For This Useful Post:
Old 07-17-2017, 18:37   #8 (permalink)
Member: 497508
Thanks Meter: 23
what model in lenovo??????
Old 07-18-2017, 00:00   #9 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Hello,
Repeat operation.
Br.
Infinity Box Team.
Phones with SLA cant be booted without AUTH file, besides normal/crypto DA agent.
Originally Posted by ChElEuLaVi View Post
Lenovo TB3-730F, Lenovo Tab3 A7-30 , Mediatek MT8161
FRP REMOVE :
- Download : Lenovo_TB3-730F_S044_161111_ROW_FRP_Remove_by_bRkA
- Unpack archive, Start SPFT from folder \SP_Flash_Tool_v5.1552.00_SecureBoot
- Press CTRL + ALT + V in SPFT, (Advanced mode) will appear in window title
- Select "Download Agent" - DA_SWSEC_CRYPTO20.bin
- Select "Scatter Loading File" - MT6735M_Android_scatter_TB3-730F.txt
- Select "Auth File" - auth_sv5.auth
- Go to drop-down menu "Options" - "Option", "Download" - select "Usb Checksum" and "Storage checksum"
- Go to tab "FORMAT", select "Manual format flash", input :
Begin address : 0x6a00000 , Format Length : 0x100000
- Tick "Validation"
- Press "Start" (Blue PLAY button), and connect powered off device to cable
- It should finish quickly
- Disconnect device from cable and power it up.
- FRP Should be gone.
* In case that you get boot-loop, OR on display written "DL Image Failed",
Simply re-flash device with provided rom file below.
ROM File : TB3-730F_S044_161111_ROW
archive pass : lenovo-forums.ru
test and post results.
p.s. PAY ATTENTION on MANUAL FORMAT, don't do AUTO FORMAT, you will kill device !!!
p.s.2 To be 100% Sure in success, before FRP remove, reflash phone with provided ROM version.
p.s.3 CHARGE battery fully before playing with device.
p.s.4 For Flashing process, same files must be selected in SPFT - same as for FRP (DA Agent, AUTH, Scatter, USB/Storage Checksum).
b.r.
Alex
__________________
The Following 8 Users Say Thank You to Brka For This Useful Post:
Old 07-18-2017, 06:41   #10 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 207
Superb work brka sir . U r the best in lenovo .
Old 07-18-2017, 13:28   #11 (permalink)
Member: 2422331
Thanks Meter: 41
FRP REMOVE :
- Tick "Validation"
b.r.
Alex
DL image fail
the ROM link that you give me is not working
thanks
Old 07-18-2017, 15:50   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
b.r.
Alex
Hello,
Correct, I really missed that-
Br.
Infinity Box Team.
Old 07-18-2017, 16:21   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
DL image fail
thanks
Your isp is probably blocking that site, try with google chrome and Hola VPN, free vpn extrnsion for chrome.
B.r.
Alex
__________________
Old 07-19-2017, 20:31   #14 (permalink)
Member: 2422331
Thanks Meter: 41
B.r.
Alex
can upload to mega.nz please
Old 07-19-2017, 20:45   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Solution already given, but try THIS also
b.r.
ALex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Page generated in 0.26291 seconds with 9 queries
