Lenovo K10a40 DA error Lenovo K10a40 Card found : S/N : xxxxxxxxxx , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! |
Try plug it to USB while keeping both volume keys pressed. Worked for me. |
Find my post in Lenovo section, about K10A40 FRP, download flasher from posted link, use appropriate DA_Agent, replace in CM2MTK folder (search the infinity section for how-to), after that phone will boot and you can do desired operations (sim-unlock, FRP remove, factory reset, re-partition, etc.). For flashing this phone you will need factory stock rom, don't use readed firmware from other same phone. more info - HERE b.r. Alex |
thanks its working :):) |
