02-25-2016, 13:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Romania, Fagaras Age: 46
Member: 34379 Status: Offline Thanks Meter: 101 | Lenovo k3 note help fix imei 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 118 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong Reconnect Power/Cable! |
02-25-2016, 13:58 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Install driver from support or C:\InfinityBox\CM2MTK\Drivers And for repair security user CM:Permanent Mode. Br. Infinity Box Support Team. |
02-25-2016, 14:14 | #3 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Did this but is not working 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 118 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42003ACFDACE321B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42003ACFDACE321B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 70C37F27EB45F9A4CB690F13204D2330 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 867609xxxxxxxxxx IMEI [01] : 867609xxxxxxxxxx Set IMEI [00] : 8676090xxxxxxxxx Set IMEI [01] : 8676090xxxxxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 118 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just reinsert cable) on this step Reconnect Power/Cable! Last edited by valiu; 02-25-2016 at 14:21. |
02-25-2016, 14:40 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Check security if it has been repaired. And when phone is reconnected for check, try to install driver manually or post vid-pid of device from device manager. Br. Infinity Box Support Team. |
02-28-2016, 20:05 | #6 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | My phone imei still null. Phone got virus and after virus scan without success, i flash phone with format option. Before that i did nvm backup. Nou can`t repair imei |
07-04-2016, 18:17 | #14 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
DO AS BRO PASSIONATE_BOYS SAYS http://forum.gsmhosting.com/vbb/11650822-post2.html WBR sahil2000ind | |
