Old 03-05-2017, 02:07   #1 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 100
Lenovo K5 Note [A7020a48] Dead After Factory Reset with CM2
Originally Posted by JayDi View Post
Hello. Wait for update. In near 2 days.
NO more MTK Module update?
Log when I tried to flash:
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A42823D084937D
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xC325AC98785DD59535BF1D156C54E299
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Main PMT update failed!
Operation Failed
Elapsed: 00:00:11
Reconnect Power/Cable!
Test:
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , 2a4GB , 0x747C00000 , 29820 MiB
[eMMC] : CID : 90014A484247346132A42823D084937D
[eMMC] : MODE : SQ-WR
[FAILED] : Probably, something wrong with eMMC! Check cable and battery!
Operation Failed
Elapsed: 00:00:14
Old 03-05-2017, 06:43   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,976
Operation Failed
Elapsed: 00:00:14
Hello,
its enough to understand
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 03-05-2017, 22:15   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,290
If it dont want to flash with factory rom and SPFT,
which can be obtained - HERE (A7020a48_S318_161128_ROW , pass : lenovo-forums.ru )
Then it's hardware problem - faulty eMMC.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Page generated in 0.21737 seconds with 7 queries
