02-28-2017, 18:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: in your Heart
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | lenovo k50a40 blue display after logo Code: Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6752 , Project : aio_5m , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lenovo Device Model : K50a40 Device CPU : MT6752 Device IntName : aio_otfp Device Version : 6.0 Device Compile : 14-03-2016 13:25:22 Device Project : K50a40_USR_S322_1603142105_mp1V2.39_ROW Device ExtInfo : Lenovo K50a40 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42000DBFDEDF527B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42000DBFDEDF527B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2F27207ED5BDB8DD8E959F98DFF58E30 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6752 , Project : aio_5m , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3820 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000006320000 Erase : 0x0000000008800000-0x000000039A580000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_aio_5m.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:09:47 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : SECRO Verify Passed : LOGO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:31 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:10:46 Reconnect Power/Cable! solution please |
The Following User Says Thank You to sidramobilecare For This Useful Post: |
02-28-2017, 23:38 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | K50a40_S433_160909_ROW (India) or K50a40_S422_160315_ROW some of them should get phone back to life (probably first one). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
03-01-2017, 07:26 | #4 (permalink) | |
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | lenovo k50a40 read info Quote:
03-01-2017, 07:34 | #5 (permalink) | ||
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | Quote:
03-01-2017, 13:26 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, If you flashed with the file posted HERE and problem still remains same then time to check hardware. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
06-26-2017, 17:00 | #9 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | Quote:
i HAVE the same issue, when start phone logo comes and then stuck on blue display. i flashed it, format, erase and done most on software levels any perfect solution for it ? | |
06-26-2017, 17:19 | #10 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | my problem solved this firmware lenovo k50a40_S327 https://cloclo21.cldmail.ru/v8incBe4...5467d510def9ff PASSWORD ROWK3NOTE |
The Following User Says Thank You to raisalina For This Useful Post: |
06-27-2017, 09:14 | #11 (permalink) | |
06-27-2017, 13:51 | #12 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Read Working Set File & Flash Only Infinity Cm2 I Solved This problem Many Times Quote:
1.97Gb | |
06-28-2017, 12:36 | #14 (permalink) |
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | |
06-30-2017, 14:21 | #15 (permalink) | |
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | Quote: Downloaded this and flash with it Same condition of the phone still i think its hardware issue, any perfect suggetion ? | |
The Following User Says Thank You to PARMATMA For This Useful Post: |
