Old 09-12-2017, 09:40   #1 (permalink)
shaikh_shoeb50's Avatar
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 124
Lenovo k8 note after reset frp dl image fail error...
FRP Reset logs
Card found : S/N : 91F8D8D6 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 41 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6797
BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0002
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , 4604F
[eMMC] : FLASH_CID : 450100444634303634011056DF8A64B7
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0xE9AEECC4853A1C47F332244F4415F9A7
INT RAM : 0x00000000
EXT RAM : 0xC0000000 [3 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
i tried Fix Dl function .....
Operation : Fix DL Errors [ v1.58 ]
Wait for phone...
Phone found! [ 41 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6797
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
DA DLFix Passed!
Done!
Elapsed: 00:00:32
But still the phone is stuck in DL Image fail error.
The phone was working fine before resetting Frp.
Now im stuck with this problem .. There is no firmware available over the net.
Can anyone please help me regarding this issue.
The Following User Says Thank You to shaikh_shoeb50 For This Useful Post:
Old 09-12-2017, 13:23   #2 (permalink)
mobite's Avatar
Member: 1800009
Sonork: 100.1654307
Thanks Meter: 806
Hi
Originally Posted by shaikh_shoeb50 View Post
lenovo k8 note after reset frp dl image fail error...
Frp reset logs
i tried fix dl function .....
But still the phone is stuck in dl image fail error.
The phone was working fine before resetting frp.
if firmware is not availaible
read file with cm2 in this condition
after read use sptool to solve dl error
select file tick on only cache
with dl checksum
The Following User Says Thank You to mobite For This Useful Post:
Old 09-12-2017, 13:46   #3 (permalink)
Member: 2756321
Thanks Meter: 12
fix dl by cm2 in seconds
Old 09-13-2017, 08:36   #4 (permalink)
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 124
with dl checksum
thnx for your attention....
i will try and post result soon...
Old 09-13-2017, 10:02   #5 (permalink)
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 124
@mobite
i have tried your method but no luck phone is still showing
tool dl image failed
Old 10-09-2017, 11:36   #6 (permalink)
Member: 2308972
Thanks Meter: 10
dm me for the solution
Old 10-09-2017, 22:16   #7 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 641
It is not that much difficult. Just read all info by cm2.. get project id and download corresponding firmware. Flash it and solved. All you need is correct project id to download correct firmware.
Old 12-23-2017, 17:55   #8 (permalink)
logicmobile's Avatar
Member: 1016569
Thanks Meter: 227
FRP Reset logs
Use SP tool instead to CM2 in case......
Page generated in 0.29295 seconds with 7 queries
