07-26-2018, 03:36 | #1 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2311387 Status: Offline Thanks Meter: 8 | infinix x559f hang on logo Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464536324D4203BD8F90612573 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D4203BD8F90612573 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0F8FE7310BBE86F921440CC2854DA421 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Infinix Device Model : Infinix-X559C Device CPU : MT6580 Device IntName : H8015F Device Version : 7.0 Device Compile : 23/01/2018 10:48:14 Device Project : X559-H8015F-N-MA-180123V10 Device ExtInfo : Infinix X559F I took a backup and returned it but the same problem |
07-26-2018, 07:55 | #2 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | There is only one solution. That's if the phone can perform wipe itself. If you can trigger the device to enter "Erasing". Your problem is solved. |
The Following User Says Thank You to Southsider2009 For This Useful Post: |
07-26-2018, 22:55 | #8 (permalink) |
Major Poster Join Date: Jul 2009 Location: lagos nigeria
Member: 1086857 Status: Offline Sonork: gsmhiprest Thanks Meter: 2 | i faced the same problem when i did a factory reset. phone kept booting and wouldnt boot up. i solved problem by flashing factory firmware. got the firmware from romkingz. just google it. and flash with sp flashtool. problem will be solved. |
