Old 11-17-2015, 10:34   #1 (permalink)
Member: 773426
Thanks Meter: 12
lenovo s650 virus NOT DONE HELP
Operation : Remove Viruses [SmartAV] [ v1.37 ]
SmartAV Conf : 100/75/4000
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B375530304D08EAF088E741B5
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : [SAMSUNG] , M00U7
[eMMC] : FLASH_CID : 1501004B375530304D08EAF088E741B5
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 6
Removing infected files and scripts ...
SmartAV Report : Removed 6 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : PostFix Ok!
the log show done, but this phone still infected
Old 11-17-2015, 12:02   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Open settings.ini in CM2MTK folder with any text editor.
Change :
Limit=100
LOF=75
Sense=4000
to
Limit=120
LOF=85
Sense=1000
Save and try again. If still error - that mean phone has already manipulated with some adb remover or some kind of such "tools".
Don't forget revert back settings after!
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-17-2015, 13:57   #3 (permalink)
Member: 773426
Thanks Meter: 12
Change :
Limit=100
LOF=75
Sense=4000
to
Limit=120
LOF=85
Sense=1000
still same
Old 11-17-2015, 14:44   #4 (permalink)
JayDi's Avatar
Member: 462970
So, that mean next :
Also, hope, you made Factory reset before run phone.
Otherwise it will change nothing, even if SmartAV done his job completely.
Old 12-02-2015, 05:30   #5 (permalink)
Member: 773426
Thanks Meter: 12
I 've found a few cases like this,especialiy samsung *******(S4, S5, Note3). I hope cm2 team can fix this problem
Old 12-02-2015, 05:48   #6 (permalink)
JayDi's Avatar
Member: 462970
I not see anything, so , not have idea what to fix or improve.
Old 12-02-2015, 13:52   #7 (permalink)
Member: 773426
Thanks Meter: 12
sorry merge post. this is for i9500 mt6572 virus s.e.x.y
i have to change setting.ini but still no luck. this is the logs:
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A4834473164048602A210699065
DA Stat : v4.2 on BBID : 0x88
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A210699065
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB
EXT RAM : 0x20000000
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 1
SmartAV Report : Removed 1 infected files!
Done!
Done!
Elapsed: 00:00:59
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.37 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:15
SmartAV Conf : 120/85/1000
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Done!
Done!
Elapsed: 00:00:39
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:17
and i already upload backup rom
virus not done(backup i9500 4,7in alpbs) - Download - 4shared
Old 12-02-2015, 14:20   #8 (permalink)
JayDi's Avatar
Member: 462970
Will check it and improve, or activate one more interest thing.
Old 12-03-2015, 03:56   #9 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
use new 1.38 exe its work for me
Old 12-03-2015, 10:56   #10 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
This does not mean that the rest of the work ..
virus is hard and is not removed.
Operation : Remove Viruses [SmartAV] [ v1.38 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A48344732611101A30268E852F1
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101A30268E852F1
[eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Done!
Done!
Elapsed: 00:01:00
Old 12-03-2015, 11:22   #11 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
Here are infected full
Old 12-03-2015, 12:39   #12 (permalink)
JayDi's Avatar
Member: 462970
This one is manipulated with some sw or something else before. All smashed and remounted. Too hard will be make something on "smart mode". Will check.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 12-03-2015, 14:02   #13 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
After the software factory. unwanted software:
viruses and malicious applications
Beauty
Cache cleaner
Easy Locker
Poly videos
SexSlave
SExxy
Page generated in 0.22196 seconds with 8 queries
