Old 02-21-2016, 08:39   #1 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
Lenovo S820 error in flashing
Card found : S/N : 42A8xxxx , v0130
Chinese Miracle II  [MTK module] v 1.41
Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Files found : 13 , Set to Flash : 12
Ready to Flash!
Operation : Flash [ v1.41 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019064314734A30586047341889A
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048605A39A884173
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 54AAE221641C3A535F487B4D634AF4A4
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3543 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002720000-0x00000000E28E0000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s820_row.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:00:32
Reconnect Power/Cable!
Need proper help to recover this phone
Old 02-21-2016, 08:59   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Make Hw test @ Extra repair Tab & post log.
Old 02-21-2016, 09:34   #3 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
cm2 error ..... can't hw test
Old 02-21-2016, 10:47   #4 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Solution already posted Here
but before Do any operation @ 1st stage if u have backup ?
just try flash with spft with this backup file ( Format+Download ) but maybe it's change nothing :-(
Page generated in 0.14072 seconds with 8 queries
