03-19-2015, 12:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | lenovo s898t+ read flash no succes Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:33 Reconnect Power/Cable! Finish at : [18.03.2015 / 16:38:27] Start at : [18.03.2015 / 16:39:20] Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! this volcano log Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6592 Hardware version:CA00 Software version:0000 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 Boot downloading complete! EMMC_ID:0x150100493855303041043A9766B16183 EMMC_PRODUCT_NAME: SAMSUNG :0x493855303041 EMMC_BOOT1_SIZE: 0x00200000 EMMC_BOOT2_SIZE: 0x00200000 EMMC_PRMB_SIZE: 0x00020000 EMMC_GP1_SIZE: 0x00000000 EMMC_GP2_SIZE: 0x00000000 EMMC_GP3_SIZE: 0x00000000 EMMC_GP4_SIZE: 0x00000000 EMMC_USER_SIZE: 0x3A3E00000(14.56 G) Analysis of USB port... >>Flash reading...7% |
03-19-2015, 13:23 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Select SP:Autodetect [6571..6592][8312..8392] Nand/eMMC in Cpu/Platform under Settings tab and try again without pressing any keys. Br. |
03-19-2015, 14:01 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | MT6592 supported for Pattern , Info, Firmware read and NVRAM read. So it should connect without any problem. Check your driver or use another pc usb port and try again. Br. |
03-19-2015, 17:31 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | After not success connect - need wait near 30 seconds for HW reset , or re-insert battery, if it non-embed. Sure, if try for start FP, then select SP and connect again - phone will be still in BAD bootrom state. |
