Old 11-03-2016, 22:17   #1 (permalink)
Member: 2465266
Thanks Meter: 5
Unhappy lenovo s90-a unknow baseband and imei ???
i have lenovo s90-a unknow baseband and imei 0 after flash with cmqlm
plz i need a help
Old 11-03-2016, 23:05   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
CM2QLM NOT touch any security partition and it CAN'T do anything with your phone imei and baseband.
1. Post SW logs - flashing atleast.
2. After logs we can try choose possible further actions.
Old 11-03-2016, 23:47   #3 (permalink)
Member: 2465266
Thanks Meter: 5
Card found : S/N : ******** v0134
Infinity-Box Qualcomm Module [QLM] v 1.00
Loading firware ...
Load Ok!
Operation : Flash [ v1.00 ]
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require make TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 035177BF
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 49C762F6FE52E492
ID_BLOCK_L : 9B939302A85331CC
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Files in Chain : 83
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : splash.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : preload_1.img
Flashing : preload_2.img
Flashing : preload_3.img
Flashing : preload_4.img
Flashing : preload_5.img
Flashing : preload_6.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Records in Chain : 26
Processing records now
Records sequence completed!
Flashing done!
Done!
Elapsed: 00:04:36
Reconnect Power/Cable!
Operation : Reset Settings [ v1.00 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP ( Google Reset Protection )
FRP removed!
Done!
Elapsed: 00:00:17
Loading firware ...
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Files in Chain : 83
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing done!
Done!
Elapsed: 00:04:16
Old 11-03-2016, 23:47   #4 (permalink)
Member: 2465266
Thanks Meter: 5
Loading firware ...
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Files in Chain : 83
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing done!
Done!
Elapsed: 00:04:36
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
FRP removed!
Done!
Elapsed: 00:00:17
Loading firware ...
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Files in Chain : 83
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing done!
Done!
Elapsed: 00:04:16
Old 11-04-2016, 01:16   #5 (permalink)
JayDi's Avatar
Member: 462970
Flashing is Ok and fw is factory one. It not contain security data.
Try press and hold volume down and wait till service menu appears. Select by side keys - restore qcn item.
All data will be reset to default.
Old 11-04-2016, 01:49   #6 (permalink)
Member: 2465266
Thanks Meter: 5
Originally Posted by JayDi View Post
Hello.
plz give me the qcn file icant found it
Old 11-04-2016, 06:03   #7 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Try press and hold volume down and Power wait till service menu appears. Select by side keys - restore qcn item.
The Following User Says Thank You to mbiborna For This Useful Post:
Old 11-04-2016, 12:05   #8 (permalink)
Member: 2465266
Thanks Meter: 5
I do that but it says check fail! I need qcn file
Sent from my D2502 using Tapatalk
Old 11-04-2016, 14:21   #9 (permalink)
JayDi's Avatar
Member: 462970
Then you should first make FW read from ALIVE phone. Not this one.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-04-2016, 14:25   #10 (permalink)
Member: 2465266
Thanks Meter: 5
How?!!! cm2qlm Don,t read the fw from this model
Old 11-04-2016, 14:46   #11 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Did u try via new ver ?
http://forum.gsmhosting.com/vbb/f296...-more-2151834/
Old 11-04-2016, 15:43   #12 (permalink)
Member: 2465266
Thanks Meter: 5
No it can't read... After searching I found that the qcn file there is in the official fw 4.4.4 but I cannot get this flash
Old 11-04-2016, 22:08   #13 (permalink)
JayDi's Avatar
Member: 462970
@alifoural, what exactly you can't read? Where logs?
Old 11-05-2016, 00:01   #14 (permalink)
Member: 2465266
Thanks Meter: 5
Operation : Read Flash [ v1.02 ]
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 07EDE44B
Use CM2 Internal Loader
Boot Ok!
Brand : Lenovo
ProdName : sisleyr
ProdModel : Lenovo S90-A
Device : sisleyr
AndroidVer: 4.4.4
Manufact. : LENOVO
QLMxCPU : MSM8916
DevInfo : MSM8916__LENOVO__Lenovo__ANDR_v4.4.4__Lenovo_S90-A__sisleyr__sisleyr
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : splash.img
[Read Ok] : oem.img
[Read Ok] : fs_gc.img
[Read Ok] : persist.img
and it stoped here with all ways change usb cable and usb hub same problem
Old 11-06-2016, 10:53   #15 (permalink)
JayDi's Avatar
Member: 462970
Stop how? Show any error log or message?
Page generated in 0.30584 seconds with 8 queries
