12-11-2018, 19:26 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: jordan
Member: 2588864 Status: Offline Thanks Meter: 62 | lenovo tab TB3-710F problem??? Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA03 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : NOT INSTALLED eMMC Flash : 15010038474D45345201D698EE544457 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R4EMG [eMMC] : FLASH_CID : 15010038474D45345201D698EE544457 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA9A792929D526B6A1E8184D0B9F7739B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery ) [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , R4EMG , 0x1D2000000 , 7456 MiB [eMMC] : CID : 15010038474D45345201D698EE544457 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:03:02 Reconnect Power/Cable! please help ........thanks |
The Following User Says Thank You to pastday For This Useful Post: |
12-11-2018, 21:37 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Make sure about FW is good and factory or from trusted source. Make sure about after FactoryReset device exactly restart as clean, not just boot to home screen. |
12-11-2018, 23:33 | #6 (permalink) |
Member: 2588864 Status: Offline Thanks Meter: 62 | Thanks...when i finish software or make full factory to the tab it is always takes about 10 minute to reach the home menue..so may be the reson for my problem in google play not installed related to hardware problem??...thanks in advance |
12-12-2018, 03:55 | #7 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Dear you must try to make a factory reset from settings after flash. Your device may be rooted, check root status, make bootloader locked and post result here... Also make a request to JayDi sir, he may help in a better way... |
The Following User Says Thank You to bhalaygilani For This Useful Post: |
