Old 05-07-2017, 09:53   #1 (permalink)
Member: 888420
Sonork: 100.1611861
Thanks Meter: 376
Lenovo Vibe C A2020a40 After Flash White Display
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 08D987D6
ID_BLOCK_I : 009600E1
ID_BLOCK_L : D3154FB7268CB9B493C80815D2A92921
ID_BLOCK_L : B0C34DDCD140EA7B9E5932EBF9342229
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000
Boot Ok!
Files in Chain : 114
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : misc.img
Flashing : splash.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : system_31.img
Flashing : system_32.img
Flashing : system_33.img
Flashing : system_34.img
Flashing : system_35.img
Flashing : system_36.img
Flashing : system_37.img
Flashing : system_38.img
Flashing : system_39.img
Flashing : system_40.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Records in Chain : 26
Processing records now
Records sequence completed!
Boot settings configured!
Flashing done!
Done!
Elapsed: 00:04:48
Reconnect Power/Cable!
I TRY ALL FIRMWARE BUT STILL SAME ONLY WHITE DISPLAY AFTER FLASH
The Following 2 Users Say Thank You to PlayGsm For This Useful Post:
Old 05-07-2017, 13:54   #2 (permalink)
mobi_soft's Avatar
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,459
what is th problem befor flash...
which version u used
The Following User Says Thank You to mobi_soft For This Useful Post:
Old 05-28-2017, 16:34   #3 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 37
same problem for me also. pls help me
The Following 2 Users Say Thank You to rajbonshi20 For This Useful Post:
Old 05-28-2017, 18:41   #4 (permalink)
rorm's Avatar
Member: 593158
Thanks Meter: 8
The Following User Says Thank You to rorm For This Useful Post:
Old 05-29-2017, 08:52   #5 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 37
my problem solved by flash with this file-''A2020a40_S_S154_161109_8G_ROW''
link- https://cloud.mail.ru/public/MkYB/McQLiX9Yc
Password-lenovo-forums.ru
The Following 4 Users Say Thank You to rajbonshi20 For This Useful Post:
Old 07-22-2017, 23:45   #6 (permalink)
Member: 227669
Thanks Meter: 4
im use old versi s190 after flash lcd wrtie screen used s129, im downgrade why write screen lcd? help me solutions master braders
The Following User Says Thank You to efridasman For This Useful Post:
Old 07-23-2017, 08:50   #7 (permalink)
Member: 2226403
Thanks Meter: 26
Bro change the lcd your problem solved.Use old lcd on non firmware write phone it`s also works i tried check it.Write all firmware is fake i test it but no luck at last i changed the lcd and those old lcd is working on others phone.
The Following 2 Users Say Thank You to gsm-raj For This Useful Post:
Old 08-12-2017, 01:20   #8 (permalink)
Member: 2746625
Same with me white screen after flash low row.
After i use high row like S220 my phone come back to life ...
The Following User Says Thank You to Abms For This Useful Post:
Old 08-29-2017, 20:57   #9 (permalink)
tatalko's Avatar
Member: 32002
Thanks Meter: 22
Is the version s220 single or dual sim?there is only one s220.
The Following User Says Thank You to tatalko For This Useful Post:
Old 11-25-2018, 03:14   #10 (permalink)
Member: 2873189
thank you very much bro
Page generated in 0.41490 seconds with 7 queries
