04-27-2017, 10:09 | #1 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Lenovo Vibe P1ma40 IMEI Repaire Problem. Before i have not come with this type of problem. All Problem was solved by CM2 without any problem. But....... This lenovo P1ma40 Phone IMEI programme says its done but IMEI is still NULL. I have flashed with different firmware also. Every thing goes ok. Repaire IMEI also ok but After power on always IMEI NULL. Need Help. Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 110 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D31323847B90042A5830CF2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200B947F20C82A5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x46F20C0C4A6F4D6861519997382F99DA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : P1ma40 ProdModel : Lenovo P1ma40 Device : P1ma40 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : P1ma40_USR_S025_1509241530_MP3V2_16G_ROW_US SECURITY : IMEI_SW [1] : 867274023997730 IMEI_SW [2] : 867274023997748 BTMAC Addr : 5427587E28DD WiFi MAC : 5427588B28DD MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P15_1_lwg _n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : FT5446 CAM [0] : ov8865_mipi_raw CAM [1] : ov8865_mipi_raw_sunny CAM [2] : hi551_mipi_raw CAM [3] : hi551avc_mipi_raw MODEM : wingtech5335_lte_l_lwg_dsds_wt_pa_sky77643_98735a LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:12 Reconnect Power/Cable! Repaire IMEI is also OK> Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 110 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D31323847B90042A5830CF2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200B947F20C82A5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x46F20C0C4A6F4D6861519997382F99DA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 867274023997730 IMEI [01] : 867274023997748 Set IMEI [00] : 867274023997730 Set IMEI [01] : 867274023997748 Prepare finished. Security check required! Wait for phone... Phone found! [ 110 ] Sync... Repair done! Done! Elapsed: 00:00:32 Reconnect Power/Cable! But Phone still shows imei NULL. Need help Please. Thanks Brother Raja |
04-27-2017, 10:52 | #3 (permalink) |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi brother. I have rooted the phone also. But same result. We are disscussing CM2 Tool here ....not any other tool brother.Please. Thanks Br, Raja |
