02-11-2019, 07:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | lenovo xt1902-3 i cant flash plaz help FRP reset protection is done using InfinityBox CM2MTK but after reset frp phone DL image error.i try to fix DL mode but Interpage come fridge thin i try to flash phone but error here is logo Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 4604F [eMMC] : FLASH_CID : 45010044463430363401BED3034D84B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x20DEE098ED5D0F0FA7914264B6F05D67 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6797 , Project : manning , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility BL : Undefined structure, determined as forced M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001B80000 Erase : 0x0000000002388000-0x0000000004000000 Erase : 0x0000000007800000-0x0000000000800000 Erase : 0x0000000008500000-0x0000000002600000 Erase : 0x000000000B000000-0x000000027E000000 Flash Erase Done, time used : 00:00:01 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
02-11-2019, 08:15 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Use Latest MTK version I.E 2.04 http://forum.gsmhosting.com/vbb/f296...vated-2556648/ |
02-11-2019, 09:32 | #3 (permalink) | |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | Quote:
my dongle is upto date | |
02-11-2019, 09:35 | #4 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, It looks like your dongle support period is expired. How to check - https://forum.infinity-box.com/viewtopic.php?f=3&t=1097 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ |
02-11-2019, 13:38 | #5 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
