06-27-2017, 13:03 | #1 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | letv x526 frp done 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 10DEFF8C ID_BLOCK_I : 007BC0E1 ID_BLOCK_L : 19EB817DD846737E291EF6DF1863F3DB ID_BLOCK_L : B5C876D9DA45F57E936237ECE6092724 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/00020000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 02C6CF16 ID_BLOCK_I : 009900E1 ID_BLOCK_E : 00000001 ID_BLOCK_L : 2340EFE1A4E96E566ED70463EB72CFAC ID_BLOCK_L : 7B590731117DDDED3F1058DDEDD7D37F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to applebricks For This Useful Post: |
