09-09-2008, 08:02 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Lg 195 Read code successfull Action: read codes unlock method: read codes Model: LG KG195 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:0CC1:742A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7332SA00-001-R1B Version: FP_0620 60 byte(s) read imei: 35673201057063 connection Ok 208 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 8833 Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
01-26-2009, 19:55 | #3 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
SHAKEEL BHAI which cable did u use with USB it asks driver n C2500 i dont have with my INFINITY_KIT plzzz help me to unlock my LG_KG195,,,,BR | |
01-26-2009, 20:01 | #4 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
LG gw read code error | deecee | FuriousGold | 16 | 02-24-2010 13:21 |
LG ks360 READ CODE unlock | gsmshapon | FuriouS II | 9 | 01-29-2010 14:06 |
Lg 195, lg 200 orignal tunes | ~The JoKeR~ | Nokia Multimedia | 0 | 09-13-2009 07:03 |
a767 Successfull read code v2.54 ! but... | nguyentung | Easy-Unlocker | 3 | 02-08-2009 15:34 |
Lg KC550 read code by vygis ok! | aikonmani | VygisToolbox | 0 | 12-11-2008 13:51 |
