07-05-2009, 07:22 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | lg 2050 cannt change imei pls help module v1.38 Device: LG-B2050 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 flash: ST M30L0R7000B0, M36L0R7040B0 B 16Mb id: 0000527A Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 350448011234561 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350448011234561_LG-B2050_20090705-115043.B1E.bin .. version: L-k[GB2050 Check flash Done Check space ... current eeprom imei: 350448011234561 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 17 sec Remove/Install battery now ! after write imei show 000000000000 in disply |
07-06-2009, 03:09 | #2 (permalink) |
Freak Poster Join Date: Nov 2005 Location: india
Member: 198115 Status: Offline Sonork: 100.1591052 Thanks Meter: 15 | i had same problem with lg2050 imei 000000000000 but via infinity it was not solved but via et-box imei ok . better try with et-box if u have. thanks |
10-24-2009, 08:01 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | I also face same problem many times before and once again. It is quite strange to me that the great time like infinity which is way ahead than any other team does not able to solve the problem like that. |
samsung f330 dont change imei pls help | scorpions_72 | Z3X-Team Products | 3 | 12-13-2009 22:34 |
new ver 2.8.2 cannt repir 5130 pls help | nazar2008 | Universalbox | 5 | 11-20-2009 12:24 |
lg kg130 not change ımei pls help me | RaSkAl01 | FuriousGold | 0 | 09-17-2008 08:23 |
Could not change e720 imei pls help | recepoz | UST Pro II | 0 | 08-02-2006 11:19 |
e780 imei change prb pls help .. | cepforum | Samsung Flashers, Software, Firmware. | 1 | 07-07-2006 15:06 |
