03-19-2011, 06:49 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
You Can Use USB CA101 Cable To Unlock & If Connector Damaged Then You Can Use Uart Point's Please Go Through These Post Carefully - http://forum.gsmhosting.com/vbb/f633...nised-1070324/ http://forum.gsmhosting.com/vbb/f633...d-now-1111934/ Wbr <<<Megatron>>> | |
03-19-2011, 07:25 | #3 (permalink) | ||
Insane Poster Join Date: Feb 2010
Member: 1243673 Status: Offline Thanks Meter: 42 | Quote:
I Tried with your above trick. but not success. i post log: Quote:
Please Help me... | ||
03-19-2011, 07:57 | #4 (permalink) | |
Which Interface You Used? Usb Or Rj45? If Usb Used Then Select Proper Port And Perform Unlock Operation Again Wbr <<<Megatron>>> | |
03-19-2011, 07:59 | #5 (permalink) |
Member: 1243673 Status: Offline Thanks Meter: 42 | no i used RJ45 Cable because i think my phone USB Connector is Problem because when i connect my phone with usb this will not responding me. so i used UART Cable with your above mentioned trick but not succeed... |
03-19-2011, 08:12 | #6 (permalink) | |
For RJ45 U Must Use Special Cable Or Special Pinout's Pls Go Through Image Here And Make Exactly Phone Must B Fully Powered On http://forum.gsmhosting.com/vbb/f633...nised-1070324/ Wbr <<<Megatron>>> | |
03-19-2011, 08:25 | #9 (permalink) |
Member: 1243673 Status: Offline Thanks Meter: 42 | okay.................... but tell me one thing if my cable is not connected properly then how to start my mobile? When i connect mobile without batter with RX-TX Jack then my mobile properly started and Says Check Batter Inside. so how i can say my cable is not connected properly??? |
03-19-2011, 08:33 | #10 (permalink) | |
Phone Get Powered When You Give Vbat And Gnd Only So There Is No Issue Regarding This Check Ur RX TX And Must B Sure That U Have Shorted Both2 Other Point's Also Wbr <<<Megatron>>> | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
