02-26-2017, 12:44
#1 (permalink)
Member: 231728
Thanks Meter: 2,104 | LG-A390 MTK6255 read flash success but write flash error bad file ? i have read flash ok in dump and scater bat in write flash operation say bad file detected read flash operation log Quote:
Start at : [26/02/2017 / 10:57:07]
Operation : Read Flash [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 41 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6255
BB_CPU_HW : CA03
BB_CPU_SW : 0002
BB_CPU_SB : 8A00
BB_CPU_NM : [MediaTek] MT6255_S0000
BROM Protocol Version : 05
Setting...
Setting done , result code 0x0000
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : 0100 B100 8000 5500
DEV[1] : 0100 B100 8000 5500
Select EMI : 01B1805500000000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85
SOC_VERIFY : 0xC1
BOOT_STYLE : NAND_FLASH_BOOT
NAND Flash IC initialized
FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA
FLASH_DIE0 : 0001 00B1 0080 0055
FLASH_DIE1 : 0001 00B1 0080 0055
FLASH_LEN : 0x08000000
INT_RAM : 0x00007000
EXT_RAM : 0x02000000
Reading Flash Content now ...
Read Ok, 0x07F80000 bytes
Saved to : D:\InfinityBox\CM2MTK\Read_out\MT6255_0E8088F00C77 _Infinity.bin
Done!
Elapsed: 00:01:47
Reconnect Power/Cable!
| Quote:
Start at : [26/02/2017 / 10:47:43]
Wait for phone...
Phone found! [ 41 ]
Sync...
Boot Info :
BB_CPU_ID : 6255
BB_CPU_HW : CA03
BB_CPU_SW : 0002
BB_CPU_SB : 8A00
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Read Ok, make firmware now ...
Scatter Configuration info : MT6255 / NAND / DDR
Saved to : MT6255_NAND_A20D_PCB01_gprs_MT6255_S00.MAUI_11BW12 16SP_W13_02
Read Done!
Done!
Elapsed: 00:01:04
| write flash operation log with error (bad file detected) Quote:
Finish at : [26/02/2017 / 10:58:54]
Load File
Bad file detected!
