11-05-2017, 17:43 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | LG-A395 format FFS done ! (world's first) All user's codes reset Operation : Format FileSystem [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 45 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Executing FFS FORMAT now... FAT_RANGE : 0x03A00000-0x07FFFFFF , LEN : 0x04600000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE NAND Status : 03A00000 / 04600000 / 00000230 / 00000001 Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to Ouzigzag For This Useful Post: |
11-06-2017, 09:41 | #4 (permalink) | |
Freak Poster Join Date: Jun 2011
Member: 1607677 Status: Offline Thanks Meter: 272 | Quote:
boot-key picture has been uploaded to support area folder \manual\UnlockAndRepair\LG\ | |
11-08-2017, 10:04 | #5 (permalink) |
Crazy Poster Join Date: Jan 2014 Location: gsmhosting
Member: 2110024 Status: Offline Sonork: Djaber213 Thanks Meter: 5 | Great job, Card found : S/N : 0D7EXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Initial Boot Failed! Error while getting BaseBand Info! Check battery/Cable , try again! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Executing FFS FORMAT now... FAT_RANGE : 0x03A00000-0x07FFFFFF , LEN : 0x04600000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE NAND Status : 03A00000 / 04600000 / 00000230 / 00000001 Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Djaber213 For This Useful Post: |
01-11-2020, 15:45 | #6 (permalink) |
Major Poster Join Date: Dec 2013 Location: Turkmenistan,Mary
Member: 2079059 Status: Offline Thanks Meter: 4 | please help me to reset user code lg A395 Start at : [11.01.2020 / 16:27:46] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 32 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : FF Setting............... and end i wait one hour |
01-12-2020, 00:07 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
