Old 05-03-2017, 08:54   #1 (permalink)
deb kumar dhali's Avatar
Member: 2234421
Sonork: 100.1674816
Thanks Meter: 60
b310e format done
Card found: S/N : C2B9E021 , v0135
Chinese Miracle II [SPD module] v 1.25
Operation : Check/Read Info [ v1.25 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 44 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Elapsed: 00:00:16
Reconnect Power/Cable!
Operation : Read FullFlash [ v1.25 ]
3. Insert battery
Phone found! [ 44 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Platform : MOCOR_W13.09_FP_R5.0.2_Debug
sc6500_samsung_PitonDS_SWA
ExtInfo : LevelofLock 00000000 00000000
Project : SC6500_SAMSUNG
HWInfo : SC6500_EiderVEDS
Compile : 11-09-2015 15:40:13
Set FileInfo :
Model Vendor : b310e
Model Name : b310e
ExtInfo Data : eng
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_SPD6500_008 00000_MOCOR_W13.09_FP_R5.0.2_Debug_sc6500_samsung_ PitonDS_SWA_11092015154013_eng__b310e-b310e.bin
Done!
Elapsed: 00:01:26
Operation : Format File System / Reset Settings [ v1.25 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 44 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:37
Page generated in 0.11255 seconds with 8 queries
