01-20-2009, 05:02 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | LG B2050 Power on After Flash LG B2050 was dead but power on after flash.... COM11 [VCP0] selected module v1.36 Device: LG-B2050 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 flash: ST M30L0R7000B0, M36L0R7040B0 B 16Mb id: 0000527A Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356558008590801 file saved: E:\InfinityBox\LGA\eeprom_356558008590801_LG-B2050_20090120-123123.B1E.bin .. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 Write: Alchemy data flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 Write Done Finished, time used: 761 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
01-20-2009, 19:38 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
Lg Cu 500 No Power On After Flashing Gold Furious!!!!!!! | rovelo | FuriousGold | 14 | 08-18-2007 17:50 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
How to fix sagem mw930 it not power on after flashing | zender | Infineon C16X M51 & ARM7 M52 BASED | 0 | 11-06-2002 08:02 |
5210 dosent power on after flash | MadPhone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-09-2002 06:30 |
Motorola M3888 don't power on after flashing :( | s.Mobi | Motorola Old Legacy (EMMI) | 3 | 03-15-2002 01:58 |
