09-03-2009, 09:35 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | lg b2060 imei 0000000000000 any way after write imei show 000000000000000000000 this log COM3 [VCP0] selected Device: LG-B2060 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 353373010033433 current otp imei: 353373010033433 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353373010033433_LG-B2060_20090903-135932.B1E.bin ........ version: XXX-XXV10l91B2060P40 Check flash Done Check space... current eeprom imei: 353373010033433 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 44 sec Remove/Install battery now ! |
09-03-2009, 11:27 | #2 (permalink) |
Member: 170244 Status: Offline Thanks Meter: 418 | yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy |
12-14-2009, 18:04 | #6 (permalink) |
Registered User Join Date: May 2007 Location: india gujrat
Member: 502031 Status: Offline Thanks Meter: 66 | 0000000000 COM4 [VCP0] selected module v1.39 Device: LG-B2060 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353373010849044 current otp imei: 355995012908119 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353373010849044_LG-B2060_20091214-222639.B1E.bin ........ version: XXX-XXV10l91B2060P40 Check flash Done Check space ... current eeprom imei: 353373010849044 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 40 sec Remove/Install battery now ! ani badi solvan pl tel me my id [email protected] |
12-25-2010, 05:42 | #9 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Gujarat India Age: 41
Member: 244135 Status: Offline Thanks Meter: 16 | |
Change lg kp500 imei without any box | sheik9905677786 | LG | 28 | 07-08-2011 23:26 |
if u have lg b2060 IMEI 0000?SOLUTION IS HERE!!!! | Rin2 | Infinity-Box | 7 | 03-31-2011 14:39 |
Lg b2060 imei 00000? | Rin2 | Infinity-Box | 3 | 12-25-2010 04:29 |
LG kg110 imei 0000000000000 | ravindrapr | Infinity-Box | 5 | 08-17-2009 13:59 |
