02-09-2016, 18:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | lg b525 Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 2 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B83B76641B9A83AEA30B132B53DDFA2D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F6 , [WINBOND] W25Q256FV [0] : FLASH_DIE : 00EF 0040 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Done! Elapsed: 00:01:02 Operation : Read UserCode [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 2 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B83B76641B9A83AEA30B132B53DDFA2D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F6 , [WINBOND] W25Q256FV [0] : FLASH_DIE : 00EF 0040 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Read ExtData Sorting ExtData Reading UserCode -- Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 2 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B83B76641B9A83AEA30B132B53DDFA2D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F6 , [WINBOND] W25Q256FV [0] : FLASH_DIE : 00EF 0040 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Backup done Executing FFS FORMAT now... FAT_RANGE : 0x01100000-0x01F1FFFF , LEN : 0x00E20000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:04:17 Reconnect Power/Cable! |
The Following User Says Thank You to nori2007 For This Useful Post: |
02-09-2016, 20:04 | #3 (permalink) |
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | read flash ok , check your pm Code: Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 2 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B83B76641B9A83AEA30B132B53DDFA2D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F6 , [WINBOND] W25Q256FV [0] : FLASH_DIE : 00EF 0040 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Reading Flash Conent now ... Read Flash now Read Ok , 33554432 bytes read Check and collect compile info File_Info : T200_PCB01_gprs_MT6260_S00.MAUI_11BW1308_MUSE_SP_W14_20_P6.bin FileVersion : MAUI.11BW1308_MUSE_SP.W14.20.P6 Saved to : C:\InfinityBox\CM2MTK\Read_out\T200_PCB01_gprs_MT6260_S00.MAUI_11BW1308_MUSE_SP_W14_20_P6.bin Done! Elapsed: 00:02:30 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to nori2007 For This Useful Post: |
