lg c 2500 imei i have a lg c 2500 ,invalid imei ,please guide me how to restore it with infinity also want to know which cable to use and where to download drivers? |
1. open shell 2. select exact model 3. when you select model in shell there is all info. about cable and software 4. press run 5. goto service tab 6. write down your desire imei in imei box 7. press write you done and there is no need any drivers for c2500 Br Faisal_Computer |
Please, use correct cable/pinout ! Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
boss ! attach usb cable and install driver thn open shell select usb port thats all |
that cable which for Lg KG195 ! BR Faisal_Computer |
Did you checked pinout from Shell well ? Please, double check Shell again, you will see C200 Rx/Tx pinout for sure. I suggest you to build (or buy) C2500 Rx/Tx cable if you still do not have it due to this type of cables is suitable for many other phones. |
please help my infinity shell not imei option how to change imei |
