07-09-2008, 08:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Chinsees Skyworks CPU ok But problem with Flash IC Device: Newgen C610 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Flash1: 00920040 error: Flash chip problem, unknown flash chip Flash2: 00920040 error: Flash chip problem, unknown flash chip Check Flash Fail Finished Remove/Install battery now ! Time used: 39 sec i m trying to reset the chinesse phone based on Skyworks CPU .. but what can be the possible cause its not resetting....... |
07-09-2008, 08:36 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | uncheck advanced auto detect chip box in settings tab.. if still same then rehot reball flash IC.. it will b resetting fine then... Br |
nokia 6280 numeric key pad ic print is ok but frornt panel keypad ic print is broken | Matwala | Nokia Hardware & Hardware Repair | 2 | 07-22-2012 08:09 |
L6 CPU Changeing But Problem | tomorrow | Motorola Hardware Repair | 0 | 06-26-2007 19:40 |
i have d500 in last open ok but now i flashed it and hang in d500 if it with sim card | gsm4libya | TST Dongle | 2 | 01-16-2006 14:56 |
