02-18-2009, 05:45 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | LG C3300 imei problem with every sim card set begain to search long time......i check its imei it was "000" the i try to rewrite imei from the back side but after repair still same imei"000".......here is log Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005271 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356021002057244 file saved: E:\InfinityBox\LGA\eeprom_356021002057244_LG-C3300_20090218-212236.B1E.bin .. Check flash Done Check space ... current eeprom imei: 356021002057244 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 20 sec Remove/Install battery now ! |
02-18-2009, 07:40 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
02-18-2009, 20:12 | #7 (permalink) | |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
COM4 [VCP0] selected module v1.36 Device: LG-C3300 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005271 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356021002057244 file saved: E:\InfinityBox\LGA\eeprom_356021002057244_LG-C3300_20090219-115104.B1E.bin .. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write Done Finished, time used: 889 sec Remove/Install battery now ! | |
02-18-2009, 21:09 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I am not sure but probably full flash from other good working may helps, but we do not have full flash files from other C3300 now. |
lg kf600 imei problem | ali125 | Infinity-Box | 2 | 12-25-2008 16:21 |
LG KG220 IMEI problem Mr. Odia help me plz | Nikola Jolov | HWK | 1 | 01-30-2008 22:12 |
LG C3300 freezing problem | Unlocker AL | Multi-Box | 0 | 10-25-2006 17:08 |
lg c3300 imei change help | simlockol | Multi-Box | 2 | 10-18-2006 16:25 |
lg c3300 charge problem | eprom_errp | LG | 0 | 08-16-2006 13:08 |
